The 12 mm wide solid copper band had the product numbers rszl12wh or rsxl12wh has anyone come across this problem and if so what did you use when clipping 6 to 12 cables to mains position.
As I did on my last job shown in picture above.
14 posts and we get to the correct question and how much.I guess that they hardly sell any so will only manufacturer it in batches of 10. what is the length per roll and how much do you use per job?
Trouble is Paul, manufacturers don't cater for proper electricians any more, one at a time cable, bash it in jobs a good un, don't think that maybe there may be more than one cable to clip. plus the don't teach much about MICC in the get rich quick courses do they?
I thought that but guessed that the OP was referring to something else.You can still obtain white all round band.
Don't know if you can get an all white band, but these were pretty good in their timeYou can still obtain white all round band.
True very true, I didn't disagree Ant it was just, it may be hard to find someone in the same position.Well, Pete, you don't know until you ask.
