A balanced 3 phase system the N load is zero, reducing the load on any phase will increase the N current.
worst case Is all fully loaded on one phase and nothing on the other 2, the N current will then equal the phase current.
Yes total load decreases but the imbalance increases, as I say not looked into the phase for many moons. Just remember we had to balance it best as possible
Yes it will become imbalanced but that doesn't increase the load!
With an unbalanced load there will be some neutral current, but with simple resistive loads the neutral current will never exceed the line current no matter how far out of balance it is.
👍Didn't explain very well but I was thinking of the neutral current.
You can only have a neutral of reduced csa if your line conductors are of a minimum csa of 16.0, copper conductor.
Interesting, I haven't really looked at it since I encountered 3 1/2 core SWA used for TPN quite a few years ago.
Can you still get 3 1/2 core SWA?
Is this a three core with a half sized neutral.
Never heard of it.
I've only seen it a couple of times, most recent was the local football stadium where they've got it feeding the four floodlight columns. 3x25mm (RYB) phases feeding 400V ballasts and a 16mm (I think) black core used as CPC.
Found a picture
Learn something new everyday but they look to the eye like sectorial aluminium with AWA in fact I'm convinced it is AWA.
