Discuss Lath and plaster ceilings in the UK Electrical Forum area at ElectriciansForums.net
Yeah that’s what I’m meaning, can you normally rod through from say the hall into the living room above the ceiling
I don't think there's much difference between a plaster board ceinling and lathe and plaster with regards using a cable rod from below. The rod will go up from below, hit the floorboards and travel along.
If however you were working from above, the rod would then hit the lathe and can be a pain on longer runs.
You may well find a few nothes you have to get past though. Ie more holes in the ceiling.
Edit... little spark has beaten me to it!
Reply to Lath and plaster ceilings in the UK Electrical Forum area at ElectriciansForums.net
Where can I get a holesaw for lathe and plaster jobs
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
