Discuss leakage test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
A
ample current
I tested a washing mashine today and it failed the leakage test.
What it the relationship of this test to an insulation test?
It gave a reading of 0.76mA
The insulaton test was good with >20M Mohms
amd earth continuity was ok too.
Any insight would be nice please.
Did you retest it? If so was it the same again?
Awkward thing to run and then try again, but did you do this?
I would like to know the answer myself..
There is not always neccessarily a relationship, as the IR test is carried out with DC, and the leakage test is carried out with AC, things like filter/suppression and motor start/run etc. capacitors which allow some AC to pass normally, but block DC (normally) can skew the results somewhat.
If this washing machine has electronics on board then I would be testing for an upper limit of 3.5mA. This machine would therefore pass on this particular test.
Reply to leakage test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi, I carry out PAT testing on landlord appliances for letting agents in rented accommodation. Occasionally some of the items I cannot access...
Hi all My Fluke tester failed on one test today while having it's annual calibration, the continuity resistance test current. Test Current -...
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
