Discuss LED downlighter stays on but diim. in the Australia area at ElectriciansForums.net
S
sivoodoo
Hi all
The LED downlight stays on but very dim when switched off. The circuit runs to the switch then to the light i.e. looped at the switch so only one T&E at light. any ideas?
Faulty switch or crossed circuits. What's your volt readings before and after the tranny? Switch off each mcb and see if it still occurs.
Reply to LED downlighter stays on but diim. in the Australia area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
Hi, I want to put downlights in my fire surround - possibly 3 but more likely going to be 2. They are 0.4w LED lights. I have a 12v 8w LED driver...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
