Discuss LED DRIVERS in the DIY Electrical Advice area at ElectriciansForums.net
In the past have bought cheap led recessed fittings as per photo attached. As you can see they come with an led driver. They are v cheap and I
have been pleased with most I have bought. So I decided to look at upmarket ones. V-TAC, whose gear I think is good do some but they cost at least three times as much and then you need to factor in a driver as well which costs nearly as much as the fitting.
Now my question is not about cost but about the specs of the drivers.
In front of me I have a driver off a cheap 12W unit. It is marked as follows
INPUT AC 85-265V 50/60HZ
OUTPUT DC 24-80V 280mA
MAX 12W
Now the V-TAC one for a similar 12W fitting is marked
O/P 24-45v DC 300mA 12W
So in the case of the V-TAC one I can see 45V @300mA is a tad over 12W
The cheaper one though looks to be able to do over 22W so am confused by noted as 12W max.
What I am trying to get around to is can I use dirt cheap drivers with the V-TAC units as long as rated at correct wattage?
i am at a loss understanding drivers for leds in general, which you might have noted.
Reply to LED DRIVERS in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, No electronic knowledge here. The plug/transformer of a led lightstring is fried. Now I am trying to find a replacement on Aliexpress...
Hello, I’ve have some ten year old Collingwood SL020 RGB led garden spike lights which I’d like to keep using but wondering if I can use them with...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
