L
Liam p
Hi there,
I have recently installed the electrics in a loft conversion and have installed gu10 LED lamps into recessed down lights. The problem I have is;
when the bedroom lights are on and you turn on the ensuite lights the lights go out for a second or two then back on?? There is a trailing edge dimmer on bedroom 1 way and on the ensuite is a standard rocker switch???
Check connections for tightness. Swap the dimmer for a rocker. See what happens - process of elimination, I suspect, trying things till something works. Your description doesn't make any immediate sense. Possibly induction somewhere between the two lighting lines? Surge as the ensuite lights go on disables the bedroom lights which then recover as the surge dies away? What happens if the ensuite lights are on and you turn on the bedroom lights? Same? Different?
pj
Thanks for the reply, I removed the dimmer and works perfectly with rocker,
does this point to a faulty switch or faulty install?
It points to something being too damned complicated for its own good!
Throw the dimmer thing away and use a proper switch.
We never had these problems when we all used candles.
Mind you, there was the night when me Granny farted too near the candle and blew the roof off ;)
LED is becoming really good but its is not quite there yet in my opinion. You can have them on or you can have them off, but not in between very effectively!! I found the best way was to include a couple of halogen lamps on the circuit in order to boost the circuit and help the dimmer work.
So for reasons not immediately obvious, switch on the ensuite (rocker) and the bedroom (dimmer) goes off/on. Switch on the ensuite (rocker) and bedroom (rocker) stays on. Logically the dimmer is the fly in the ointment ... Are you looping in/out at the dimmer switch point or just running a switch drop to the dimemr?
pj
