Discuss LED lights in communal area strobing in the UK Electrical Forum area at ElectriciansForums.net
SparkyAndGeorge
Hi all,
Been called out to communal lights in a flat communal area. 3 out of the 9 LED lights are strobing roughly once a second. When the timelag switches are pressed the strobing stops and the lights illuminate as they should but when the timelag switch pops back out the strobing starts again. I measured the voltage and am getting
S/L - N = 60v/120v fluctuating
S/L - E = 60v/120v fluctuating
P/L - N = 230v
N - E = 0v
Any suggestions please? Many Thanks
put one only incandesant light on the circuit,
this usually fix's it.
must be incandesant, cannot be led or cfl.
The easiest way is to swap out one of the led bulbs.
Same fixture just put a small incandesant in there.
Reply to LED lights in communal area strobing in the UK Electrical Forum area at ElectriciansForums.net
A BG fused connection unit, with neon. A boiler. Fuse out. Spur switched off. I was checking polarity after a colleague had 2nd fixed it and...
I had just installed a heat alarm on the downstairs lighting circuit during a kitchen rewire. The new kitchen ring / cooker circuit I tested IR...
I have a issue with lights flickering in my home. Specifically led lights. I’ve bought a lot of brands of led lights and even most of the...
Just spent 4 hours tracing out a lighting circuit to try and find a fault. I came across a switch that was switching the neutral. This threw me...
