J
jjrules2
Hi,
On a job today the client had some LED lights that aren't working. LED transformer is OK and 12v is at the lights. The lights are wired in series (as it says they should be on the fitting themself) and are wired in the following way -
Twin and earth from transformer - Brown to Light 1
Blue in connector block
Brown from another cable goes in other side of Light 1
Blue in connector block with original cable
This pattern continues, so at each light you have one brown going into the fitting, then another brown coming out of the same fitting to the next. The blue's are connected in blocks.
The problem I have is what to do at the end, as this is where I found bare live cables not terminated! The last light has one cable coming from the previous light, so I assume I attach the blue in a connector block and the brown in one side of the light. Then there is a cable going from the last light to the vert first light where the 12v comes in as well. Just want to know how to connect the last light and first light really as the middle 6 lights are all brown in brown out neutrals connected.
Thanks guys
Thanks guys
