Thanks I've been on their website already they don't do the traditional style in a large enough size and they didn't give a bespoke option. Thanks
This lot do two ranges of LED Lighting that can be powder coated to many different finishes and made to measure. Might be a little too modern, but might do the trick with the arched mounts. If budget is big enough, just get it gold leafed.............
Vision Depot
Thanks the Drummond one looks good just a little too small looking for something around 1.2m to go along the top of a large menu black board, The vision depot stuff looks like the same type of light that Portland lighting do, There going to go into a rock theme kind of bar and grill red walls retro fittings in brass etc. Thanks
I got some good cheap ish ones from the electric ctr. not as pricey as the plumb ctr they have a fantastic range collingwood robus etc. collingwood have loads of led gear
I take it you will be offering a electriciansforums member discount?
:D
Jim
pennywise,
dufjax,
