Discuss LED picture lights in the Electrical Tools and Products area at ElectriciansForums.net
Thanks I've been on their website already they don't do the traditional style in a large enough size and they didn't give a bespoke option. Thanks
This lot do two ranges of LED Lighting that can be powder coated to many different finishes and made to measure. Might be a little too modern, but might do the trick with the arched mounts. If budget is big enough, just get it gold leafed.............
Vision Depot
Thanks the Drummond one looks good just a little too small looking for something around 1.2m to go along the top of a large menu black board, The vision depot stuff looks like the same type of light that Portland lighting do, There going to go into a rock theme kind of bar and grill red walls retro fittings in brass etc. Thanks
I got some good cheap ish ones from the electric ctr. not as pricey as the plumb ctr they have a fantastic range collingwood robus etc. collingwood have loads of led gear
I take it you will be offering a electriciansforums member discount?
:D
Jim
Reply to LED picture lights in the Electrical Tools and Products area at ElectriciansForums.net
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
R
I am looking into LED lighting for a Grade I listed church, parts of which are 800 years old. The lighting must be simply dimmable with a colour...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
