• Please checkout this (ad-free) update post I've done on a spare blog. Feel free to bookmark it and check everynow and again for update if ads are pissing you off. Always feel free to ad-block them for now though if you want. I'll let you know when you can disable the ad blocker again, only if you want to see the ads. They should look nice and neat in the end.
Discuss Led strips controllers and power in the Electrical Forum area at ElectriciansForums.net
I am looking to purchase 5m of LED RGB+CCT strip and 2 ZigBee controllers, the controllers can take up to 6 amps, the LED strip has a max draw of 72 watts at 5m, I was planning on only using 1m on each controller and purchasing a 12v 6a power supply just incase I use the full 5 meters between the 2 controllers, would spliting the power to bother connectors work correctly as I'm planning, sorry if this is completely wrong I am a novice when it comes to working out power draw on things.
Reply to Led strips controllers and power in the Electrical Forum area at ElectriciansForums.net
hello all, I am about to start a mildly ambitious project with some addressable RGB led strips. I am still shopping for the perfect strip and my...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
New Posts (Please Reply)
