Discuss LED's - Selecting the correct driver for lamp in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Could someone please tell me what has happened and please advise:
I recently modified a large 5x halogen bulb lamp bought from 'Next' to take G4 LED's. I selected appropriate 3W LED SMD bulbs and got a 20W LED driver to run the 5 bulbs. There is no dimmer, its just on a foot on/off switch.
All was fine for a couple of weeks but then i noticed the bulbs were getting very hot and starting to flicker. This lasted a couple of weeks. Then on one such occasion the bulbs suddenly went very bright before the driver blew up.
I followed all the guides etc, so dont understand why this is happening. Would really appreciate some guidance.
Thanks. Jack
Depending on the driver, it may have suffered damage when you’ve turned on your luminaire. LED lamps have a slight surge in power when turning on. Seem to recall a factor of 1.6 x max load should be allowed for, I’m sure someone will correct me.
It could also be a compatibility problem between driver and lamps or cheap products.
What are your lamps and driver?
Hi Midwest,
Could you recommend a supplier for driver and LED's ?
What driver would I need to run e.g. 5x 3W G4 bulbs ?
Parts were sourced off eBay, so cheap really. I'm not at home at the minute to verify driver. Bulbs are not branded, just have 3W 250LM text on the side.
Unfortunately I sourced most of my products from my local wholesalers.
You could try someone like one of the forum sponcers Electrical Wholesalers | Electrical Supplies | Electrical2go - https://www.electrical2go.co.uk/
or someone like Buy LED Light Bulbs Online @ UK LED Lighting Supplier LightRabbit inc. GU10, MR16, B22, E14 LED Bulbs... - https://www.lightrabbit.co.uk/
I would suggest with 5 x 3W lamps you’ll might need a driver of at least 24W. Speak to their tech department, if they have one, explain what you are trying to achieve and see if they have suitable products.
Reply to LED's - Selecting the correct driver for lamp in the UK Electrical Forum area at ElectriciansForums.net
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
I have a replacement LED driver for a lighting circuit that had normal halogen G4 bulbs. The forum has already put me onto the right track by...
I have touch lamps that came with 3w G9 Non Dimmable LED bulbs that obviously work, but are too bright i have been searching for 1.5 W LED bulbs...
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
Hi - I have a room lit by two undimmed strings of six x 4.5W MR16 no-brand non dim lamps. This system originally had 50W halogen MR16s and 2 x...
