F
FinderOfSpiders
The light fixture in one of my rooms has randomly started flickering after about 20 years of use. I tried 8 different bulbs and the flickering doesn't go away so I think it has something to do with the wiring of the light. I took it down and saw this:
I think the loose wire at the top was meant to go in the larger wire nut at the bottom and just came undone when I took the light down. (we compared it to a similar fixture elsewhere in the house). Took the nut off, added that wire back in and twisted the nut back on. We also wrapped the broken insulation in electrical tape and then screwed the whole thing back in place.
The light still flickers and is even dimmer than it was before I "fixed" it. Does anyone know what commonly causes this problem? Did I probably just do a bad job? should I just call someone to fix it for me since I'm not very comfortable working with home wiring?
All help is much appreciated
- TL;DR
- Light flickering/not happy
