Discuss Lighting and socket off one fused spur in the UK Electrical Forum area at ElectriciansForums.net
Hello, just wanting to know if I can take a fused spur off my ring main and take it to one outdoor socket as well as an outdoor light. Or weather I’d need to fit 2 fused spurs. So one goes from the ring to the socket. Then another fused spur from the outdoor socket to the lights? Cheers
What’s the outside socket for?
A single outside light is classed as a fixed load… shouldn’t need fused down again.
13A inside will be fine.
Reply to Lighting and socket off one fused spur in the UK Electrical Forum area at ElectriciansForums.net
Im just curious as to peoples thoughts on the following install I seen on a video from an Electrical firm today and they did the following: Ran...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
