@Dumkopf
As well as the lighting question, are you aware that, when you make your house 3-storey, you will need to install interlinked smoke alarms on all storeys of the house?
I guess you have a building notice for this work? You need to make sure this sort of thing is covered, or your friendly Building Control operative will be less than friendly.
Hello All, I'm very grateful to you for your attention.
Apologies if my question was unclear. I think that telectrix interpreted it correctly. I know that the new circuit is notifiable. I just didn't know if it required to be on a separate fuse for Part P compliance.
Yes, I did know that the smoke alarms must be interlinked, but thanks anyway.
Part Pee doesn't require you to do anything
Its up to you what you install , Part Pee only comes into play if you add new wiring and don't have it signed off
There are several ways to achieve this
Use a Part Pee domestic sparks
Use a Part Pee 3rd party
Pay the BC to do your Part Pee
Only applies if you need new wiring , if you just modify the existing then non of the above matters
I can now see why you were confused by my question; if I'd used the word "wiring" instead of "circuit" I'm sure it would have been clearer. Thanks again for all your advice.
Wrong.
Part P applies to all electrical work.
The legislation says this
and you’d want all of the electrical work to comply with that!
the APPROVED DOCUMENT, however, is guide (not law) on how one can comply with the Statute.
the APPROVED DOCUMENT basically recommends that a way is that you comply with wiring regulations (BS7671). It also details certain works that the Local Authorities would like to know about (notify).
And there’s a load of fluff about how that works.
Wrong.
Yes but it doesn't tell you how to install (new or modify) and tell you how to do to comply
There are various ways to wire any extension and various way to comply (if req)
If the work complies with BS7671 then it will pass muster.
BS7671 doesn’t tell you the practical side if anything. It tells you the “rules” you follow to achieve the end result.
