Discuss lighting on 3 phase in the Industrial Electricians' Talk area at ElectriciansForums.net
benji
keep coming across switching probs.where you have large area's of lighting spread across three phases,we used to use barrier sw/boxes apparently we don't need them now just stick a 415v label on the switch.Then you get the problem with multi gang switches with say three metal conduit drops and if your not looking somebodies got switch wires & phases down different conduits
would welcome any thoughts on the above
yours benji
happens all the time they're either marked or its belling out time got a nine gang to deal with at the moment 5 circuits 8 switch wires
did i forget to mention three are two way??
Reply to lighting on 3 phase in the Industrial Electricians' Talk area at ElectriciansForums.net
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
