Discuss Limited Space For Out building supply in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I am looking a installing a new supply to an out building, but very limited in space in electrical cupboard.
Could you use a double pole mcb in place of a switched fused disconnect ?
If not could you please enlighten me as to why.
Thanks all.
Hi all,
Thanks all.[/QUOT
Not in your CU because the CU will be single pole so a DP wouldn't compute
Let me know your location I'm willing to visit and advise if you like.
Thanks all.
How big is the incoming supply and the new supply you are installing?
Possible reasons for choosing a fuse over an MCB are a high level of fault current or the need for discrimination.
Why do you need the DP MCB?
The problem with using MCBs upfront like that is discrimination, sorry... selectivity.
When you say space is limited, how much room do you have available? A picture may help.
Allegedly the DNO's don't like you putting your stuff in 'their' meter cupboard. Bit like fake Earth Moon landings or the Flat Earth. Could enquire with them though.
Reply to Limited Space For Out building supply in the UK Electrical Forum area at ElectriciansForums.net
Hi all, with majority of new builds adopting loop at the switch for residential lighting circuits these days, am wondering if any one still...
We have a 5.5kW incoming supply, which cannot practicably be upgraded due to our remote location in the mountains. Can I use a PV array and...
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
Hi, client wants some sockets and 20a switches moved into high cupboards in kitchen and above 1200mm for tvs etc, the apartment was built in 2016...
Hi all, any recommendations for neat and complaint ways to "house" a new supply -- the main electrical fuse, cut out, meter etc that on our house...
