Discuss Loft conversion install in the UK Electrical Forum area at ElectriciansForums.net
well, as ever, glad to be of help :p
I'm sorry you feel the way you do, but since you won't be back on, if you take one bit of advice from here, let it be this-
when you get your quotes, just remember that cheapest isn't always best, and that tradesmen aren't all just after your money. for the most part, they take pride in their work, and that takes time which costs!
Cheers Dan and I will get three quotes and go from there. Its more about the right install for what I need rather than cost.
Reply to Loft conversion install in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi. We live in an older house and we are doing a loft conversion. We do not have an SPD on the connection to the grid and the builder's...
5K
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
I’ve recently moved into house and had an electrician out to install some new lights and shaver point in an en-suite. Problem is that the house is...
