Discuss Looking for a VFD with good scaling for display. in the Electrical Engineering Chat area at ElectriciansForums.net
Evening,
I currently use Rexroth VFD´s, but the scaling options are a bit sparse.
Basically it has a multiplier that you can set from 0.1 to 100.
For example on a pillar drill I added one to, I wanted the display to show RPM, but as the motor is geared down (for example 12:1), you only get two decimal places and you can't get it accurate enough.
I know I´m being ----, but is there a low cost VFD that has a multiply and divide for scaling?
Thanks.
Evening,
Thanks.
add a display meter to the setup they can be scaled to whatever you like from a 0 to 10v input
That’s a way, I was hoping to find a reason to use a different drive this time though!
Looking at the Siemens V20 it has a multiplier and divisor but it’s so hideous to look at!
Thanks.
Reply to Looking for a VFD with good scaling for display. in the Electrical Engineering Chat area at ElectriciansForums.net
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
So, for a bit of completely pointless fun really, does this antique looking item that was acquired entirely for novelty/aesthetics value work...
I have a question for you all, We recently moved, and the old house had the analog meter on it, the new place has 3 structures on the property.. a...
This one might get the old grey matter going! 400A supply 260m run on ladder fed from BS88 fuses to sub main distribution board. Did a cable...
9K
Hi, my missus is giving me grief every time I empty the expensive gear from the motor every evening, as most gets left in the hallway. I'm also...
