Discuss Loose cable, clamp remedy for in the DIY Electrical Advice area at ElectriciansForums.net
Imagine please a long extension cable with an electric mower at one end and a circuit breaker plugged into a wall socket in an inaccessible place at the other.
It is not unusual for me to inadvertently unknowingly put pressure on the system such that the plug or the circuit breaker no longer connects. This leads to an unnecessary series of checks to see where (else) the problem (blown fuse?) might be.
Has anyone come up with a simple "cable clamp", screw-in wall mounted, that I could feed the cable through such that the circuit breaker or plug is protected from accidental pulls?
You could attach a simple cable clip on the flex below the socket, attached to the wall…. But that won’t stop you pulling on the flex while mowing.
It’s actually better that the plug comes out, disconnecting the supply and notifying you of a problem, rather than the flex becoming damaged as you pull against the clip….. still live.
Longer extension lead, or smaller garden.
Thanks. I think that in the circs the extension lead is plenty long enough and the problem has more to do with dislodging the circuit breaker and plug in their location. I have had a quick google for cable clips and clamps and of course there is a huge range of options. Some look more viable than others
Couple of suitable sized p-clips maybe.
More words: p clips
More words: p clips
What I think I'm looking for is what I would call a "cable clamp" - in the sense of a clip that can be screwed into a base but has a quick release "latch" that permits temporary removal of the cable without unscrewing. May be there is a technical term for this?
Reply to Loose cable, clamp remedy for in the DIY Electrical Advice area at ElectriciansForums.net
A few weeks ago I posted this in another thread...: The tripping kept occurring, so I went back and moved a likely candidate circuit to the...
I'm having a terrible bout of imposter syndrome here - I can't find anything electrically wrong with my intention - but it feels a bit off...
Had a nightmare of a day trying to get a small 2 bed 1900 or so terrace house through its EICR today for the landlord. He's one I work for, so...
4K
Having closed down my business and gone to employed, I have a garage full of unused stock..... Looking to get rid of it as one bulk sale, am in...
Ok Hello all and thanks for having me. I need some advice and joined this forum hoping to be pointed in the right direction. First off I am not...
4K
