Discuss Lost for words......... in the UK Electrical Forum area at ElectriciansForums.net
Yes why the board change? There are some very cost effective ways to resolve this that do not warrant a board change unless there are other undisclosed issues with the board or your customer is interesting in upgrading anyway.
To be fair it was gonna be a board change but it may be left as that. Will look back in tomorrow and determine it then. Other than the two lighting circuits not being covered by rcd there isn't any other reasons.
The patch is fine as long as you used some decent glue thus won't drop off, lack of rcd's only warrants non compliance note but was to regulation when installed if that is what you suspect.
I personally would leave the board as is, explain to the customer there is no reason to upgrade then explain the benefits of a modern board without pushing them into an upgrade and just say you would be happy to quote it if they ever decide to upgrade it.
I simply cannot believe any real sparks would have left the consumer unit like that with a ruddy massive hole in the bottom.
It had to be a builder installer or Diyer ....
Absolutely standard diy shed hook up.
Seen dozens just like this every year.
The best one most recently was a 10mm g/y used as the ‘washing line’ and 2.5mm red / black singles tied to it using bin bag ties to supply power to a garden work shop. Over a span of about 30metres.
The insulation on the singles was all blistered and crumbly from years of u.v abuse. When I took it down the red and black insulation just crumbled into bits
When you say this do you mean that because it was ok when installed it is ok now. Eg it passed 16th edition regs and still complying with 16th,, surely then electricians would need to know what was contained within each edition and the time line for each? I don't get this surely all testing is done to the current regs??
Yes all testing and inspection is carried out to current regulations. However you only code non-compliances relating to safety, you don't code an item which does not comply but has no effect on the safety of the installation.
For example red and black t&e doesn't comply with current regulations but doesn't affect the safety of the installation.
For instance the 18th now states when installing trunking that u need fire clips inside...previously u didnt. Doesn't mean you now have to take it all down and start again. I code it a c3 and mark it down as 5.2 in schedule of inspection where it says cables being correctly supported in their run.
Reply to Lost for words......... in the UK Electrical Forum area at ElectriciansForums.net
I’d welcome your feed back….! As after 35years doing the job.! Knowing about it for 10years.! I came across my first ever experience of...
Today I was doing an EICR and went around a couple sockets with a Megger MST220 socket tester just to see if there was anything obvious, all three...
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
I was surfing through one of the electrical training groups on Facebook yesterday and came across this question from an AM2 prep course: There...
Does anyone else get emails and phone calls from companies and agencies say we seen your CV and we want you to apply for our job. And when you...
