It got even better when I popped my head out the back to see a shed supply
I guess they wanted to utilise the supply for a washing line as well
When you say this do you mean that because it was ok when installed it is ok now. Eg it passed 16th edition regs and still complying with 16th,, surely then electricians would need to know what was contained within each edition and the time line for each? I don't get this surely all testing is done to the current regs??ut was to regulation when installed
For instance the 18th now states when installing trunking that u need fire clips inside...previously u didnt. Doesn't mean you now have to take it all down and start again. I code it a c3 and mark it down as 5.2 in schedule of inspection where it says cables being correctly supported in their run.When you say this do you mean that because it was ok when installed it is ok now. Eg it passed 16th edition regs and still complying with 16th,, surely then electricians would need to know what was contained within each edition and the time line for each? I don't get this surely all testing is done to the current regs??
