G
gazzamikes
hi guys,
have wired up my mates fully pumped system 2x2 port sprung returns valves. he has also plumbed in underfloor heating (Uponor system) as a separate system but obviously wants to run the same boiler.
ive been going through the drawings and having a fiddle in the wiring centre and i can see no possible way of running the two systems apart without the use of a couple of relays and a bit of thought. the wiring diagram for the uponor undefloor heating makes it appear very simple but on further investigation it is showing the underfloor being on with the normal heating but he doesnt want that.
the problem i see is that both the ehating systems require the use of the boiler and their own pump, i see it as pump runs boiler fires up, sounds simple but when wired as per diagrams etc both pumps become common and both run.
has anyone has this problem?
hopefully this all makes sense
thanks!!!
thanks!!!
