O
Octopus
OK, its best to mount extractor fans high on walls, or in ceilings but how effective would one be mounted lower down the wall?
scenario - the outside wall is part wall and mainly sloping ceiling - so its possible to mount the fan at waist height and then have a short run down to the eaves.
Any thoughts or experiences?
can't quite visualise what you describe. do you mean fit fan in sloping ceiling or on wall below?
Building regs require as close to the ceiling to ensure warm moist air is extracted as well as install according to manufacturer. Clearly warm moist air will convect upwards and will condense to water lower down so the fan will fail in removing warm moist air at that level is my thinking. Why not vent through a tile?
A decent fan will not need the hot air fed to it - it will vacuum the room air out - so as has been discussed, a decent fan will do the job if no other way of mounting it.
It’s always advised that there is adequate air to enter the room to prevent zero gravity with good quality fan extraction (i’m sounding more like @static zap everyday!)
Has there got to be a happy medium between clearing the warm damp air and taking the heat out of the whole house in winter? The nearer the fan is to the ceiling you can get the former done but if you have to use a too powerful extractor you end up throwing out all the warm air from whatever rooms are open to the kitchen which has to be replaced via window vents and the like and has to be reheated
Could the fan be connected with some form of ducting?
Overall it will be less effective for a matching fan at a higher level, however if you ensure an increased air flow with easy replacement air and better direction of extraction from one end of the room to the other then it may be more effective.
Convoluted extract paths, no replacement air and user non operation will have a greater effect than low level installation.
Needs to be low enough to effectively extract but not too low so as you smack your head every time you check to see if your scrambled egg is sticking to the bottom of the pan.:D
I'll probably use an ICON fan and the run to the sofix will only be a couple of feet so it'll be nice and efficient...
On another forum, one of the members worked for the makers of ICON fans. They was some sort of management change, and cuts were made in the manufacturing process, resulting in poorer quality products from previous examples, apparently. This particular member then left, so it might be sour grapes, but he said things ain't like it used to be.
I think the problem of mounting the fan lower, will result in some of the damp air condensing on surfaces, causing mould etc. Mounting higher up or via the ceiling will extract more of the moist air quickly, reducing condensation & mould.
Of all the examples of mould etc I've seen, most were where the fans have been mounted lower. So go higher IMO
@Murdoch personally id go for a "Continuous" MEV fan something like a Greenwood Airvac CV2GIP, and just check you have a 9mm undercuts under the doors to allow airflow.
The trouble with intermittent fans is that when you delve into Part F and do the calculations it works out that these types of fans require so much background ventilation it usually almost impossible to achieve in a double glazed property.
Most houses just havent got enough windows to put enough trickle vents into to acheive the required background ventilation.
A customer called me regarding a new bathroom she had just got fitted in the loft.
Building control was involved and they wouldn't sign it off until an extractor was fitted.
Long story short the easiest and only option without major redoing of the bathroom was to fit extractor aprox 3 ft from floor to go into a crawl loft space then out through eaves.
I contacted building control to see if they would accept that. They did and works competed and signed off.
Wonder why building regs says ceiling level then?
Stale air tends to be warmer than fresh air so it rises. Hence extraction or return air is generally taken out at ceiling level.
Extracting from a lower level won't usually have a profoundly negative effect as long as there's nobody going to be sitting in close proximity in which case it might be a bit draughty.
high up as possible, it's simple physics. Unless the fan is so powerful it's causing a general draught in the room it will be like draining a header tank by punching a hole through it half way up.
we have a lower fan approx eye level due to sloping wall/roof higher up, and the air stratifies, so you can see clear air below eye level but above eye level is clouds of fog.
We are going to move to ceiling above the shower, extract into an HRV before it has a chance to spread.
"low" extractor fan ..........
Octopus,
johnduffell,
