radman2020
- Reaction score
- 0
I have undercabinet lights that are low voltage. They work xenon pucks just fine. I want to convert to low voltage LEDS. Supposedly these are 12V DC but when I hook 12V DC LED pucks up, they don't work.
There is a switch to turn these on that is 120 volts. Somewhere buried behind the wall is a 120 to 12VDC converter. I can't access it. I am assuming there is too much current to the lights so the LEDs won't work... maybe more than the 12V. I bought a multimeter but it doesn't show any voltage. I put the wires together and I get a spark so I know there is power. Maybe I am using the multimeter wrong? I put the probes to each end of the wire. I also put it to one end of the wire and to a ground. Nothing.
In the end, I want the LED's to light up but they don't seem to want to respond to the power getting to them. Is there anything I can do??
