Rather than fixating on the details of how it might be done, take a step back and consider what you actually want/need out of this.
What you have stated is this is primarily about access - so you can reach the board without trouble. That is a good start and a perfectly valid reason for moving the CU, but is moving it down by a metre or two the best solution? Will it be in the way of anything else in that location, or are there better places that are still within a sane cable-extending reach?
Next thing is you say you are going for RCBO. I think most folk here would agree is the best solution, so that is unlikely to be a contentious point with anyone you get in.
Typically with a new CU most would recommend getting a Surge Protection Device fitted following the guidance in the 18th edition of the wiring regulations. You don't
have to get that, but some CU come with it as standard and those that don't it is normally less than £100 more to add a Type 2 SPD (unless you have lightning conductors installed on the building, are rural or otherwise fed from overhead cables, you are unlikely to need a Type 1 SPD). For peace of mind and lower risk to everything downstream of the CU it makes sense.
How many circuits do you currently have? Could you do with any more in the foreseeable future? Generally the cost for a larger CU box is trivial (it is the extra RCBO and effort to test circuits and fit them that would add cost) so for future expansion you should allow a couple of spare slots.
Do you have solar panels or similar local power sources? Are they doubled-up on an existing circuit? That is not permitted (but sadly common) so this would be the time to sort it out properly!
Are there any other things you want sorted as well? Normally before a planned CU change the electrician would do a ECIR to identify any unexpected problems and at that point the cost/effort to complete things properly would be clearer. Given your interest in this I doubt you have any obvious faults that are being ignored (e.g. broken or burned-out sockets, etc).
You might want to look over the best-practice guide #1 on CU replacement, and the guide #4 on inspection report aspects so you are familiar with the sort of things that any competent electrician would be looking to address.
https://www.----------------------------/professional-resources/best-practice-guides/
