Discuss Main earth bond reading in the Australia area at ElectriciansForums.net
I am ....
Then yes i'm fairly sure its that!!!!!
Also was in formed that the same figure (0.05) is used from connection of bonding clamp at meter to any other point( ie pins on the nearest socket outlet was the exact example used) should also be 0.05 max
can anyone confirm????
sorry if that was round the wrekin:):):)
28.75m
About 0.175 ohms
Reply to Main earth bond reading in the Australia area at ElectriciansForums.net
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
