Discuss Main equipotential bonding conductors in the Industrial Electricians' Talk area at ElectriciansForums.net
Is this a test?! :eek:
*whispers 'No' and don't make anything worse off than before (except possibly someone's bank balance :D)
Well, that link says that IT IS notifiable (I think? - Doesn´t mention "upgrading" but...)
The list below describes the types of electrical installation work and locations that require advance notification to your local authority's Building Control department.
Type of work
  • New installation, rewire or partial rewire
  • New consumer unit
  • One or more new circuits
  • Extension to circuit (in kitchen, special location*/installation**)
  • Main/supplementary equipotential bonding
on my NIC building regs notification site ther is a list of work that as been carried out and you click on what work you have done,equipotrential bonding is on that list,
believe it used to be notifiable when part p first introduced...was changed to non-notifiable mid 2006 something like that
Reply to Main equipotential bonding conductors in the Industrial Electricians' Talk area at ElectriciansForums.net
I'm probably displaying my ignorance here, but fortunately I'm not one of those people who can't stand to be laughed at! I've been thinking a bit...
Hello, I have a customer who is looking to replace their electric shower. There is equipotential bonding connected to the cold feed. I’ve not seen...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
J
Is it simply a case of bonding the 2 METS with a conductor large enough to carry diverted neutral currents.
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
