Discuss Main equipotential bonding conductors in the Industrial Electricians' Talk area at ElectriciansForums.net
Is this a test?! :eek:
*whispers 'No' and don't make anything worse off than before (except possibly someone's bank balance :D)
Well, that link says that IT IS notifiable (I think? - Doesn´t mention "upgrading" but...)
The list below describes the types of electrical installation work and locations that require advance notification to your local authority's Building Control department.
Type of work
  • New installation, rewire or partial rewire
  • New consumer unit
  • One or more new circuits
  • Extension to circuit (in kitchen, special location*/installation**)
  • Main/supplementary equipotential bonding
on my NIC building regs notification site ther is a list of work that as been carried out and you click on what work you have done,equipotrential bonding is on that list,
believe it used to be notifiable when part p first introduced...was changed to non-notifiable mid 2006 something like that
Reply to Main equipotential bonding conductors in the Industrial Electricians' Talk area at ElectriciansForums.net
Hello, I have a customer who is looking to replace their electric shower. There is equipotential bonding connected to the cold feed. I’ve not seen...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
J
Is it simply a case of bonding the 2 METS with a conductor large enough to carry diverted neutral currents.
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Morning All, Think I'm having a brain fart but I have a 70mm2 4 core SWA with a separate 35mm2 CPC. Earthing is TNS with main bonding...
