Discuss Main switch and breaker arrangements which way..... in the UK Electrical Forum area at ElectriciansForums.net
Do you prefer to do them I prefer Main on left breakers to the right 6A > Highest reason for asking ? I have seen a few pics on here of late with main on right.
ATB J
I usually reconfigure to suit the installation, and like Lenny said High to low (as this was the way I was taught) from the MS/RCD.
Sometimes on CU replacements this is not always easily possible, but I try to keep to this convention where possible, I suppose since almost all CU's nowadays have 100A busbars this is not as important as it once was.
Reply to Main switch and breaker arrangements which way..... in the UK Electrical Forum area at ElectriciansForums.net
I note that in answer to another EV Charger question a member suggested a 40A breaker would be preferred to a 32A because of many hours at...
Hello, I am a homeowner and have a solar project coming up. I intend to install a 9kw solar system but I am not sure if I have to upgrade my main...
Hello mates. i have an MK CU to replace. As you may know, the main switch in MKs is on the left hand side. There's no way to replace the...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
