Discuss Main water Bonding in the Electrical Forum area at ElectriciansForums.net
If the incoming water main is plastic can I assume that there is no need to run a 10mm bonding cable to the stop cock
hi there
i ahve seen somewhere in the regs that it is not necessry to bond incoming plastic water pipes i think it is in the onsite guide
cheers
If the incoming from the St is in copper then fine I beleive that the point of the bonding is to asssist with ADS which the parallel path will do, not for supplemtary bonding of the copper pipes within the dwelling am i right in this??
Reply to Main water Bonding in the Electrical Forum area at ElectriciansForums.net
