Discuss Main water Bonding in the Australia area at ElectriciansForums.net
Hi.
Even though the incomer is plastic chances are carrying on from there will be copper, so I would run a bond to the stop cock.
Cheers.
If the incoming water main is plastic can I assume that there is no need to run a 10mm bonding cable to the stop cock
hi there
i ahve seen somewhere in the regs that it is not necessry to bond incoming plastic water pipes i think it is in the onsite guide
cheers:)
I thought the point of bonding the incoming services to the MEF was to ensure that if parallel earth paths exist the ZS is improved at the board which enhances ADS. If the incoming is plastic goodbye parallel path path????
What about combined installations? Those that have both plastic incomming and some copper and some plastive. If you boneded the copper it would only bond untill it reachs a plastic fitting. In fact the whole house could be done in copper but if plastic pipes are fitted then its useless.
If the incoming from the St is in copper then fine I beleive that the point of the bonding is to asssist with ADS which the parallel path will do, not for supplemtary bonding of the copper pipes within the dwelling am i right in this??
Chaps,
Basically, bonding is to prevent voltage appearing through the underground pipework.
If its plastic, it cant get in.
Reply to Main water Bonding in the Australia area at ElectriciansForums.net
Doing an EICR on a commercial install, there’s a copper pipe comes down a pipe chase with the stop cock fitted onto it, it’s then pvc pipes that...
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
