S
sparks1234
We have been asked to carry out some delaps works on a small flat, believe me it is small and we tried swinging a real live cat, the funeral is friday.
Everything is fine within the flat, new consumer unit to be installed using the existing tails as they are in a Kopex type tube. The original main earth was 6mm and we have pulled a 16 mm through to replace it. The tails are 16 mm (not unusual) but the cutout fues is 100 amp on a TNC-S system.
The idea of installing larger tails is a bit of a nightmare as it will require surface trunking as they would not go through the Kopex, would the leccy board just replace the fuse for a 60 if asked?.
