Discuss Manrose wf300 instructions in the UK Electrical Forum area at ElectriciansForums.net
Cheers dude prob is fitted a replacement window mounted under warranty after motor failed in 1.5 yrs and now week old replacement fell out of Window yest apparently nearly on someone's head ! Just to see if I had/hadn't done something stupid only fitted a few window fans but previous 12" was secure etc. Think the tenant may have pulled external grille for cleaning and undone the 4 fixings and dropped the fan unit out by accident tbh
should have used gorilla glue. then even GMES would not have been able to pull it out. :tounge_smile:
Think I should tbh
All 4 fixings pulled thru which is nice haha
looks like a bit of vandalism there to be fair , or screws overtightened and expanded due to heat or direct sun ..
Looking at that grill after a week , it is little wonder the previous one only lasted a short time.
It's absolutely stinking their only a small cafe. The guy mentioned as I was leaving that it wasn't level inside in his opinion so maybe had a go at it. Also trying to get me to silicon it to the window due to vibrations he reckons caused it. Fitted fine was a bit tight as Louvres were a bit of a squeeze but I slackened it off incrementally to fit perfect tight but not too much tbh
I think you are right . for all four to break is a bit extreme. I'm sure the ones I used to fit had a cushioned seal, but it has been a long time.
I hated fitting them.
Reply to Manrose wf300 instructions in the UK Electrical Forum area at ElectriciansForums.net
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi all, working at a house where a British Gas have installed a Chint iso off their meter. The isolator is a Chint NHB2-100UK 100a unit but...
Hi. I've been asked to install a Dimplex qm150 storage heater for a customer. There is a suitable existing supply for the off peak element...
