Discuss Marcrist Core set with dust extract in the Electrical Tools and Products area at ElectriciansForums.net
123
Has anyone used one of these? Have a few jobs coming up that need a fan cored through red brick wall which tend to be a nightmare as the wall is wet and the dust jams the core drill.
This is the item
Agree with above; burnt out one core drill with just one hole in wet garden brick work. If wet core drilling is available for hire, I'd go with that.
Not keen on the idea of wet core drilling, the jobs are domestic bathrooms, and I'd imagine the clean up operation after 1 core will be a nightmare. There is no issue doing the core dry, it's just it takes around an hour on average and it's the wet/damp dust that slows things down, if the kit in my opening post brought that down to 30 mins, then happy days.
The Marcrist dust extract system is pretty good.
A few issues:
If using a core bit with slots, you need to tape them up to stop the dust flying out. The tape wears off and needs renewing for each hole drilled.
Using a Henry works OK, but I suspect that the restriction in airflow causes the Henry to get too hot from lack of ventilation. Maybe need to allow some extra air to bleed in.
I start my cores by screwing a disc of wood to the wall, cut to the inside diameter of the core, as a guide. You don't need a pilot bit so can use extract from the start. Once you're a few millimeters in, you can remove the guide block.
One thing I found that helped with damp brickwork was to get the core started then SDS four holes 10-12mm at 12, 3, 6 and 9 oclock.
It helps to keep the damp clay like dust from building up and binding the bit.
this was with Eurbauer core bits from Sxcrewfix, never tried the expensive ones.
Reply to Marcrist Core set with dust extract in the Electrical Tools and Products area at ElectriciansForums.net
Hello, I am currently working with 2 separate circuits, one for the dust extraction and another for a circular saw. Both circuits have an...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
This isn't very electrical, but never mind! I'm adding an extractor fan to a bathroom in a 4th floor flat. The builder has helpfully cored a hole...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
