Search for tools and product advice,
Discuss Max Zs permitted values.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
davie2876
Hi guys n gals think I messed up my last post as it be gone... Anyhow got a question C32 30Ma 10k RCBO on a standard final ring with the same supply characteristics as ANOTHER final ring off the Db 6 inches from it...
Live been going through the O/M manual and found the test sheets and these 2 IDENTICAL circuit have different max permitted Zs values..... One is 1001 the other 0.6???? Am I being stupid as the are wired in same cable using same method doing same thing fed from same supply???? Anyone shed any light??
what do you think the maximum permitted ZS is?
And lee I ain't saying what I read is totally wrong etc I'm just curious as to thoughts or if I've missed something as ive dissected this but can't get my head round it
I wonder if the first figure should read 1667 ?, maybe two different operatives ? and one has put the max Zs for the RCD part and the second has put the max Zs for the MCB part ? just a thought.
Reply to Max Zs permitted values.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm just hoping I can cross reference my knowledge or be corrected by someone on a quick query. It's a test question I'm doing but I'm querying...
9K
Just processing an EICR and noticed a couple of final circuits measured Zs values (fed from a sub distribution board) slightly exceed the Max...
12K
Bobster
B
Hi all. Love the forum by the way. I do have a question though... I have just visited a house (on a Sunday!). Customer is asking for additional...
Z
Apologies if this question sounds a bit basic but am a little confused at the mo and quite new to the game. Here goes - I am trying to complete...
4K
zak325
Z
B
On an Installation Cert in the 'Max Permitted Zs' column should i put the tabulated values in the regs or should i put the corrected values(x0.8...
