Discuss Maximum LED load on a Lutron Maestro Pro Dimmer in the DIY Electrical Advice area at ElectriciansForums.net
jpalatine
I have Maestro Pro dimmers throughout my home. I have remodeled the kitchen and want to upgrade the lighting. I desire to put 15 10-watt led can lights on one Maestro Pro led dimmer. The Lutron representatives say "no problem" but I would like to make sure that is the case before I run all that conduit. Anyone have a real answer? Thank you.
Jpalatine welcome to the forum and 15 lights at 10 watts per light, that’s just 150 watts which is just 1.5 amps so the switch contacts is probably rated for 10 amps. I don’t see a problem
Reply to Maximum LED load on a Lutron Maestro Pro Dimmer in the DIY Electrical Advice area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hi guys, I was hoping for some guidance in installing a light switch. This is my first post, so I hope this is in the right forum. In my...
