This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
L
luckyjammygit
Hello
Just had a new Boiler put in and missed the Electrician.
he has left a note to say:
No visable sign of MEB
Recommed MEB 10mm ASAP
No phone number left.
I have phoned British Gas Installer and he tells me this is nothing to worry about as the guy just did not bother lookin for a Bond?
Could someone explain what is happening here?
yup. the electrician means that he sees no bonding to the gas/water etc. advising it's done with 10mm, which is correct. ( could be 6mm if the installation is not PME ). it could be that it's there and he's not looked hard enough, but either way it needs checking. I suggest that youlook close to the water stop tap and the gas meter to see if there are clamps on the pipes with green/yellow cables attached.
if british gas have been anywhere near it, they'd have bonded at the meter, even if the meter is 50 yards away down behind the outside bog.
Hello
Gotta love british gas installers.. no bonding nothing to worry about!!!
Could it be Tel, that the "Engineer" does not see a proliferation of Green and Yellow cables they normally see attached to the pipework that enters the Gas Boiler?? Most Gas fitters I have come across don't know the difference between Main Equipotential bonding and Supplementary bonding, just a thought
Just had a new Boiler put in and missed the Electrician. he has left a note to say:
I assume it's a gas combi and the Electrician was also GasSafe registered?
Sounds like he was too lazy to bother looking for the bonding and is fishing for another callout to remedy the AWOL conductor.
No Heat only and looking at paperwork more closely has charged £189 for main earth bonding.
British Gas has charged £189 to carry out part p electrical connections including main earth bonding where required.
Cannot see any clamps or cable around Gas Meter.
Onto customer Service who have promised to ring back.
As no longer trust BG
How much for private installation?
You cannot give a price for installing the main bonding without knowing the extent of the job i.e length of run for cable, cable route etc... So it might well be a fair price. But if there is no evidence of any earth clamps & cable connected to your incoming water and gas service pipes ( assuming it's required for both) then you are in your right to question the bill and an explanation for why the MEB was not installed.
Hi - bonding is for safety. When faults occur bonding works to keep you from being exposed to dangerous voltages. It is a mandatory part of an installation. Putting the BG thing to one side, perhaps you could ask for a nice electrician to give you a quote via a forum post? Plenty of nice electricians listed here :)
