C
clydey
dropped my megger - about 2 ft -it worked ok after for 2 tests.
noticed all the leds lit on top screen and would not switch off except by removing batteries.
all internal fuses checked ok and all connections ok and no damage to pcbs.
i am presuming this fault is not actually a fault but a vibration detector sensing the fall and putting the megger into check mode.
Q.noticed several pins on the inside on one of the pcb's including the reset pin does any one know the specific reset sequence.
i imagine it woud go like short reset pin to pin x and connect battery remove short - check mode cleared
cheers
cheers
. Poor thing bounced but still worked. I had it calibrated shortly after.
