Discuss megger in the Electrical Tools and Products area at ElectriciansForums.net
Future proof and get the one with bluetooth :) hope one day they put this kind of thing on the sticky threads section what test kit comes up so much, not ripping into you M8.
if you get the 1553 - will you be doing enough certificates to justify it? - dont forget you will need the software for it as well +/- £150 - PC/laptop and printer....a megger rep said to me dont bother with bluetooth unless all you do is test..........:rolleyes:
bought mft 1553 brand new(?) of *bay on Sunday. still waiting for delivery........ seller even did not bother to contact me:mad:
Get te 1553 both are excellent if you do pat testing as well get the pat 4 and the software as it will work with the 1553 as well.
Chris
Best tester ive used, But personally think i wasted money on the blue tooth and the software,, megger software that i got was unable to email to clients , i now have the nic software that you can email to clients and they can print them straight away.
I find the MFT1552 perfect for my needs with the only different between it and the 1553 a lack of the Bluetooth function.
I'm used to filling in certificates or reports on draft paper then entering the data into the software I use which is on my PC (Tysoft EasyCert) ready for printing and binding.
Reply to megger in the Electrical Tools and Products area at ElectriciansForums.net
Hi I've got a megger mft 1720 that I was hoping any one can shed any light on When performing continuity tests (even when nulling the leads)...
Hi I’m just starting to do ev chargers so it’s looks like I need new tester. I currently have Megger 1711. So I can’t do a 6ma rcddc test. I...
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
