Discuss MEM 20 amp. rewireable fuse in the UK Electrical Forum area at ElectriciansForums.net
S
skywalker100
Hi does anyone know if the above are available? I have a board that has a 2.5 radial on a 30 amp and need to drop it down. I have used Wylex In the past (rewireable and mcb plug ins) but not sure if I have seen a MEM equivalent. .
Well, the fusewire is available. :confused5:
when you derate 2.5 mm to allow for using a BS3036, even clipped direct it's down to 19A. the 15A 3036 will happily carry that all day. so why bother trying to use 20A?
Reply to MEM 20 amp. rewireable fuse in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi guys, Rewired a unit where they make dentures, builder today has asked to install 16a commando socket with isolator (no problem) however...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
