EvilDrPorkChop
- Reaction score
- 0
We've just recently bought a property which is around 25 years old and will be completing some alterations. The consumer unit is in the Utility high up on the wall. Isn't in the ideal place and we'd like to move it, due to a new kitchen layout.
On further investigation the meter tails run up the cavity to the consumer unit (I can see from the outside meter cupboard)
After a bit of research online I see this is a bit of a grey area. We'd like to keep the consumer unit in the same vicinity but move it horizontally across the wall by about 1m and down the wall so it's lower down (More or less the same height as the meter box outside) In affect the meter tails would be running horizontally across the cavity instead of vertically, but within the 3m rule I have seen about the tails.
Is this allowed? We'd get an electrician out to look but current situation we can't and are trying to plan ahead.
