Discuss meter tails in the Australia area at ElectriciansForums.net
F
fusion
could anyone please advice..
is it ok to run meter tails from an existing supply to a second board about 20meters away to supply a 8way split board wich will run 2 stand up sunbed capsules and a ring circuit and a lighting circuit..???
Fusion, if you intend on installing a new set of tails into the henley blocks, you need to be aware that the maximum run for mains tails is only 3m. You could always fit an fused isolator next to the henley blocks, and come from that using swa or twin pvc etc to the new board..:)
Reply to meter tails in the Australia area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hello again, Was looking at installing yet another dedicated consumer box for my EV charger off the henley blocks and i noticed that a meter...
Hi, I was hoping someone with a little more insight might be able to shed some light on a potential issue I have, as I can't seem to find another...
7K
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
