Discuss microwave heating issue in the Electrical Appliances Forum area at ElectriciansForums.net
I have a swan 20l nordic digital microwave which turns on everything seems normal but when cooking does not heat anything. any ideas how to fix this? I saw videos on replacing a fuse but in my microwave the spring fuse thing they replace i can not find in my microwave.
It is more than likely the magnetron is faulty
Microwaves should not be opened unless you really know what you are doing. There is a huge capacitor in there which, unless it is discharged correctly and safely it can kill, even when the microwave is unplugged!
I already checked the magnetron and it was just fine, no damage.
Reply to microwave heating issue in the Electrical Appliances Forum area at ElectriciansForums.net
Hello All I was hoping for some advice. We have a microwave and recently after cleaning, as soon as the microwave was plugged in, a loud humming...
Hi, Just been scratching my head about this one and wonder if I've missed anything. A few weeks ago I installed a new circuit for a 3kw oven and...
when installing circuits protected my mcb's , i have always used the 80% rule. eg a lighting circuits where the load won't exceed 80% of the mcb...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I have some Hafele swan neck over cabinet LED lights in my kitchen. They are about 15 years old and a couple have failed. They are now...
