Discuss Microwave tripping circuits on two separate CUs in the UK Electrical Forum area at ElectriciansForums.net
Hi All
Bit of a strange one...
My mother in law decided to poach an egg in the microwave, and whatever she did, the egg went bang and knocked out the kitchen sockets.
Strange thing is, it looks like this also tripped circuits on a separate CU which feeds external sockets & lights etc.
It could be that the external CU had already tripped before the kitchen sockets went off but there's no way to tell.
Both CUs are fed via a 4-pole (British Gas installed) isolation switch, so is there any way the microwave could have affected separate CUs?
Many thanks
Phil
External CU is possibly fed from CU feeding kitchen sockets. A few pictures would help, of the various CU's - not the eggs
The outside CU is independent of the internal CU. I have a 4-pole isolation switch after the meter, from the switch are the two CUs - other than sharing the same isolation switch, they're totally separate.
is it a flat . picture would help.
It's a house. I'll have to post a photo in the morning.
Hi Phil - welcome to the Forum !
When you say tripped - what exactly tripped on each board ?
The MCB for the kitchen sockets tripped on the house CU and the MCB for the outside sockets tripped on the outside CU - the outside CU only has one used MCB (for the outside sockets).
Many thanks for your replies.
Reply to Microwave tripping circuits on two separate CUs in the UK Electrical Forum area at ElectriciansForums.net
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
I was recently called to a domestic nuisance tripping job, dual-RCD Wylex board with one of the RCCBs tripping intermittently, mostly during the...
6K
Hi all, So I’ve been having a strange fault in my house which has just appeared over the past few days. About a month ago I moved my pc set up...
14K
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
