A Ajf100q Feb 25, 2021 #1 Hi, do you need to compete a minor works cert if you are just moving a socket and not altering the circuit in any way? Thanks.
S Strima Feb 25, 2021 #2 Yes, as you're making an alteration to the circuit and you need to record your test results.
Flanders ~ Arms Feb 25, 2021 #3 If your moving the socket then you are altering the circuit. So yes a minor works cert is required
