Hi guys I'm new here.
As in the title, been having an issue with my shower. The LED on the pull chord goes off when I turn the shower on. Lights on the shower do not come on either and no water comes out.
So far, I have changed the latching switch and the solenoid coil but no luck.
Any ideas?
It's more than likely the N in the pull cord has become loose, ore was not connected properly in the first place, the cause you are experiencing will probably be "pull cord ON shower On current causes the N to break contact, result Pull cord OFF Shower OFF repair, get an Electrician involved, change the pull cord don't waste more money changing stuff in the shower body, you don't need to change.
Any ideas?
If the light on the switch goes out when the shower is switched on this indicates a loose/burnt connection at the pull switch or somewhere heading back to the consumer unit.
I suppose the moral here,is a proper testing method,would determine exactly what is the fault is,instead of gueoping.
(that's yllis,for guessing and hoping:))
I replaced the pull chord switch and it sorted the issue (ages ago, forgot to reply). Have done this once before already but the problem was slightly different as the light on the switch didn't come on at all.
Thanks for the help folks. :thumbsup:
Glasgow
Mira Sport 9.8kw Shower Problem
AJ284,
AJ284,
