Discuss Mounting DIN rail in boxes in the Electrical Engineering Chat area at ElectriciansForums.net
wheeto
Hello,
I'm looking for a bit of advice: does anyone have a satisfactory way of mounting DIN rail in adaptable boxes? I normally end up mounting the box, then drilling through the box into the wall behind and mounting the DIN rail that way, but it feels a bit wrong ... does anyone have a good way of mounting DIN rails to the enclosures themselves?
Thanks,
4mm brass screws with the heads on the outside back of box. nuts inside.
Apologies @davesparks I didn't realise he was after a metal one
It wasn't clear, but I made the assumption based on plastic boxes having mounting bosses and pre cut din rails that if someone is fitting their own it is likely to be a metal box.
Plus he said adaptable box, which to me is always a metal box, I'd always call a plastic box a plastic box, or 'enclosure' as seems to be the trendy way of putting it.
Hello,
Thanks,
All the ones ive used usually have raised fixing points for fixing din rail, usually fix using a 1/2" flange head screws.
Depending on what I'm doing I may space tje din rail off with washers to allow wires to be run behind.
Depends on where and what surface you're mounting your dist board / adaptable box.
I have used in the past cut unistrut bars with Zebedee bolts and 6mm roofing screws for both plastic and metal dist. boards.
Doesn't look too hot in many domestic environments but fine for sheds, workshops, garages, and just about all commercial / industrial installs.
The question was how do you fix din rail inside an adaptable box, unistrut seems a bit extreme for that
I used this method to keep the enclosure from the wall, makes an easy access SWA termination, allow SWAs, pyros, FPxoo to run underneath when there is limited space, and use any combination of screws / bolts to fit the dinrail to the enclusure and then an easy mount onto the unistrut.
Reply to Mounting DIN rail in boxes in the Electrical Engineering Chat area at ElectriciansForums.net
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Hello All Has anyone come across a problem fitting the front cover on the Hager Design 10 board over some RCBOs and a Disconnector switch? The...
