Guest viewing is limited
W
wiggly
Has any one fitted a commercial job onto a domed roof any ideas going out to see the client tomorrow
regards
wiggly
Do you mean true domed or just curved in one direction, - done the later just a case of choosing the correct mounting systems and aloowing for the curve effect on the wind loading / uplift / overturning which will be much greater than on a single plane or flat roof.
True dome it will require a bespoke mounting system designed by a structural engineer to support / fix.
Worcester, thanks for the reply,
it is a true domed roof (bus garage) I was thinking along those lines but take on board the structural ,wind lift issues.
regards
wiggly
Mounting On a domed roof
Thread Tags
wiggly,
wiggly,
